Activity Forums Blackmagic Design Intensity Shuttle Problems
  • Intensity Shuttle Problems
    Posted by Matthew Bradshaw on September 21, 2011 at 9:47 pm
    Hi. I am having problems installing an Intensity Shuttle. I have USB 3.0 and have downloaded the Desktop Video version 8.5. I have installed it and tested my disk speed etc. Every time I open Media Express I get the Blue Screen of Death. Avid does not see an input from the Shuttle. I have set it up in Control Panel. Any suggestions?
    Matt.
    Edit: I should add that I have an Xbox attached via composite. I have been able to grab a frame in Photoshop set to NTSC.
    Steve Binder replied 13 years, 7 months ago 6 Members · 12 Replies
  • 12 Replies
  • Kristian Lam
    September 22, 2011 at 6:00 am
    Hi Matthew,
    We currently don’t support Avid which is why it won’t be seen in that application.
    Can you check what version of the USB 3.0 host controller you have running?
    regards
    Kristian Lam
    Blackmagic Design
  • Matthew Bradshaw
    September 22, 2011 at 6:35 am
    Hi. I am no expert, could you tell me where to look for that? I have, I hope attached an image of my device manager usb settings.
    Matt.
  • Matthew Bradshaw
    September 23, 2011 at 7:53 pm
    Hi again, I am not bothered that Avid is not supported for capture but could you still advise me how to get this working? Media Express seems to crash my computer every time I use it. I can capture stills in Photoshop.
    Matt.
  • Ethan Cord
    September 26, 2011 at 10:14 am
    Looking at your screenshot of device manager, it seems you have an ASMedia USB 3.0 controller. The Intensity Shuttle doesn’t work with this, you need to be using a Renesas or (if you can find one) a Fresco Logic FL1009 based controller.
    I’ve seen a few reports of BSOD, or general crashes when trying to use the Shuttle with an ASMedia controller. When I tried it myself, I got a video passthrough/preview, but the capture window was black.
  • Matthew Bradshaw
    September 26, 2011 at 1:56 pm
    Hi Ethan, many thanks for your help. I don’t know much about all this stuff, does that mean I need to install some new software or buy a new usb 3.0 card, or do I need a different PC?
    Many thanks, Matt.
  • Matthew Bradshaw
    September 26, 2011 at 4:46 pm
    Hi. I can only find cards with Fresco Logic FL1000 chips. Would that work? Or would this Renesas based card on Amazon work https://www.amazon.co.uk/Plugable-Express-SuperSpeed-Expansion-Renesas/dp/B003UDCPEI/ref=sr_1_6?ie=UTF8&qid=1317055442&sr=8-6
    Many thanks, Matt.
  • Ethan Cord
    September 27, 2011 at 6:55 am
    Hi Matt,
    Yes, if your onboard USB 3.0 is ASMedia, you need a Renesas based card.
    I have a generic Renesas based card plugged into my Asus Crosshair V Formula and it works perfectly with the Shuttle.
    Avoid Fresco Logic FL1000 cards as they don’t have enough bandwidth.
    EAC.
  • Joshua Helling
    September 28, 2011 at 6:57 pm
    I have a board in house with an ASMedia controller. I had the weirdest time with it. When I first got it and tried it with the Intensity Shuttle it didn’t work at all. When I tried it on the Ultrastudio Pro it did work but in SD only. Once I got it working in SD, it started workin in HD. But I never could get the shuttle to work for some reason. Now that we’ve gotten the Ultrastudio SDI we are gonna try it with that. But yeah…this chipset is weird.
    Sincerely,
    Joshua
    Director of Support
    Blackmagic Design Inc.
  • Matthew Bradshaw
    September 28, 2011 at 8:15 pm
    Hi again. Just in case anybody else is dealing with this. I bought the card mentioned above from Amazon and it works fine. Thanks for all the advice.
    Matt.
  • Mike Magnoli
    October 22, 2011 at 8:57 pm
    My computer is showing the same symptoms (blue screen whenever I use media express) but my motherboard is a Gigabyte 990XA-UD3 and it has an Etron USB 3.0 Controller. Will purchasing a Renesas PCIe card allow my intensity shuttle to work?
