Activity Forums Blackmagic Design Intensity Pro….no SD capture
  • Intensity Pro….no SD capture
    Posted by Scott Francis on November 10, 2011 at 12:46 am
    I have had an Intensity Pro card for about a year now, used to be able to capture from Beta SP desk YUV through the card into either Media Express OR Vegas 10 in SD format. No longer the case, I have tried BM Desktop versions 8.0-9.0 to no avail. I have to upconvert SD to HD in the BM menu and then I am able to capture in Vegas and then set to SD fromat in the NLE. Also cannot capture anything from composite or S-video anymore as well. Only real change is the drivers from BM…anyone else have this issue? Thanks in advance!
    Warmly
    Scott Francis
    Mind’s Eye Audio/Video Productions
    Scott Francis replied 14 years, 9 months ago 2 Members · 2 Replies
  • Danny Hays
    November 13, 2011 at 6:33 pm
    You are selecting composite or s video in your BM control panel right? Also the source input must match the capture settings in Media Express prefs or it won’t work.
  • Scott Francis
    November 22, 2011 at 1:03 pm
    THANKS DANNY! I had not seen that option in the newer versions! It was not there before in 2.6 that worked fine….I will try that out. I was only aware of the BM control panel.
    Regards
    Scott Francis
