Activity Forums Apple Final Cut Pro Intensity Pro work around, capture direct into folder “FC Event/~/Original Media”, god idea?
  • Intensity Pro work around, capture direct into folder “FC Event/~/Original Media”, god idea?
    Posted by Jonas Bengtsson on October 11, 2011 at 10:08 am
    While waiting on drivers for Intensity Pro card so we can capture direct with FCP X like with FCP 7.
    Is capture direct into folder “Final Cut Event/~/Original Media”, god idea or does it messing up the the Event Liberary and Render-transcoding process.
    Jonas Bengtsson replied 14 years, 11 months ago 3 Members · 3 Replies
  • Jason Jenkins
    October 11, 2011 at 10:30 am
    [Jonas Bengtsson] “Is capture direct into folder “Final Cut Event/~/Original Media”, god idea or does it messing up the the Event Liberary and Render-transcoding process.”
    If you are capturing directly to a Quicktime format and have transcoding turned off, you should be OK. You’ll have to restart FCPX for the media to show up in the event library.
    Jason Jenkins
    Flowmotion Media
    Video production… with style!
  • Ben Scott
    October 11, 2011 at 12:51 pm
    why not just get it link to media on import
    you wont be able to capture and have it keep updating in FCPx
  • Jonas Bengtsson
    October 11, 2011 at 1:41 pm
    One less step in the workflow makes life little easier, one step less make the possibility for a mistake smaller.
