Activity Forums Blackmagic Design Intensity Pro ~ Patience wearing thin
  • Intensity Pro ~ Patience wearing thin
    Posted by Chris Mulhall on December 19, 2010 at 8:14 pm
    I bought a BMIP in November, on an old machine. It didn’t really function as intended but i soon fixed this with my new system. I bought a mid range PC:
    CPU: G6950 @4.2GHz
    GPU: GTX 460 1GB
    Mobo: Gigabyte H55M-UD2H
    HDD: 1x 500GB WD Caviar Green (With Win7 x86)
    1x 1TB Hitatchi (which i record to, has a write speed of abotu 100MB/s.
    Will be getting a 1TB Sammy Spinpoint F3 in two weeks. this has better write speed, i may RAID the two 1TB’s also.
    My BMIP sat comfortably in the case, connected to an Xbox 360, then to a TV. It worked flawlessly for the first few weeks.
    Now though…
    I have changed NO setting, NO drivers, NOTHING, and it refuses to work at all. I cannot view video on the preview window, and there is no video passthrough (720p 59.94) to my TV. I am stick with a £130 card that’s doing nothign except collecting dust at the moment.
    I record with Media Express after issues in the past with VirtualDub and AMCap.
    The problem became intermittent about a week after i got the new system. It was fixable by restarting both systems, but i get nowhere with that approach any more. I am thinking of sending it to BM for repair/replacement, their customer support has been good, but far too generic to be of use.
    SS
    Chris Mulhall replied 15 years, 9 months ago 2 Members · 3 Replies
  • Dale Mullins
    December 20, 2010 at 12:50 am
    Chris – What type of connectivity do you use to the Intensity Pro? HDMI or component? I have the Intensity Pro (older, HDMI only) and use it for Xbox 360 recording.
    I have forgotten in the past that it is capturing and would start something with HDCP enabled (Netflix, Zune, …) and the card would cut out and quit capturing (and it should, because of the HDCP). I simply went to System Restore (in Windows) and rolled back to the latest snapshot and it fixed it.
  • Chris Mulhall
    December 21, 2010 at 5:19 pm
    I have it on HDMI
    But i know it’s not even detecting is because it used to BSOD my PC if i turned off Media Express while the xbox was on aswell. Now it doesnt, i assume it isn’t even being recognised. Its like the card isnt even connected. It gets hot and displays green artefacts on my TV when the PC is booting up though, so it must be working to some degree.
    What can i do? Is this software issue? I hope its not a problem with the card itself…
  • Chris Mulhall
    December 24, 2010 at 11:50 pm
    Can anyone help? I’m getting so annoyed with it!
