Activity Forums Blackmagic Design Intensity Pro output issue
  • Intensity Pro output issue
    Posted by Pascal Nocquet on January 24, 2015 at 3:39 pm
    Hello
    I have a set up with a Macpro 3,1, and two monitors (iyama), OSX 10.8.5. I’ve added an intensity pro to get a third screen (same iyama), for client wiewing while I’m working. I’ve installed the latest drivers (10.3.5) from Black Magic, and the screen is connected with an hdmi>DVI converter on the cable.
    So I thought that should work.. Except when I turn on the monitor, it goes all red. Plus it’s visible in After Effects and FCP7, but not Premiere (CS6), and not real time. Am I using the wrong drivers, or is it the cable?
    If anyone had a beginning of an answer, that’d be really appreciated..
    Pascal Nocquet replied 11 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
