Activity Forums Blackmagic Design Intensity Pro issues in Windows 7
  • Intensity Pro issues in Windows 7
    Posted by Luke Rieschiek on December 30, 2009 at 12:12 pm
    I am using an Intensity Pro to capture video from another computer (running a VJ program) to feed into a 3rd party app (MediaShout) which adds text and graphics and projects the output to a display screen. I had this running over HDMI on win XP, but now I’ve put the card into a Windows 7 system and can’t get it to work.
    In HDMI, I get green & pink images, but nothing appears in MediaShout. I’ve also tried it in YPbPr, it works properly in ME, but I still get nothing in MS although it does recognise the device. I’ve tried vaious comnbinations of formats, resolutions and refresh rates, but this is as far as I can get.
    System specs:
    AMD Athlon x4 630 quad 2.8GHZ
    4GB DDR2 RAM
    Windows 7 Pro x64
    Any assistance or direction is appreciated.
    Luker
    Luke Rieschiek replied 15 years, 2 months ago 3 Members · 3 Replies
  • Nathan Goodfellow
    December 31, 2009 at 2:44 am
    I am also having issues with Windows 7 and the Intensity
    I have a DVI to HDMI converter cable hooked up to one computer that outputs my VJ software to the card.
    So far all I get is black screen, no flicker or anything
    Nate
    http://www.softthoughts.info
  • Larry Brewer
    June 1, 2011 at 10:56 pm
    I hope you found a solution to this problem you had a couple years back.
    I have been trying to get an answer to a Windows 7, MediaShout, BlackMagic Decklink Extreme configuration for the last 2 weeks.
    In your configuration, I assume you were using a BlackMagic card to output MediaShout video as opposed to a standard PC graphics card?
    MediaShout doesn’t see my Blackmagic card. Is this typical?
  • Luke Rieschiek
    June 9, 2011 at 2:47 pm
    I haven’t solved it yet, just worked around it with SD over IEEE1394, but I’d like to get it working again. I’ve tried the Windows 7 drivers which were released since, and still no joy. MediaShout sees the card as a source, but the video doesn’t come through.
    I’ve just read that it could have something to do with changes to DirectShow / Media Foundation in Windows 7, but I’ve no idea what to do about it.
    I’m currently using a GeForce 9600GT for the graphics output. We’ve upgraded the video player system (other computer), so this one will only need to key text over the video. If there’s a way to get the Intensity Pro to do that, it would be awesome.
    Your configuration would most likely be supported by SongShow Plus
