Activity › Forums › Apple Final Cut Pro Legacy › Intensity Pro Hangs Mac (FCP 7)
Posted by Ben Edwards on June 27, 2012 at 11:20 pmHi, I have been using an Intensity Pro to monitor video in FCP but it is causing Mac to hang. Seems to happen every few hours. I can edit for days without problems in I don’t use Intensity Pro for preview.
I am using the latest drivers (published a few days ago) but it happened with alder drivers also.
Any Ideas,
Ben—
Ben Edwards – Freelance Picture Editor
https://www.funkytwig.comMacpro1,1 2007 6GB RAM 2*2 3Ghz Xeon
Michael Gissing replied 14 years, 2 months ago 3 Members · 7 Replies -
Michael Gissing
June 28, 2012 at 12:36 amAre the latest drivers for FCP7 or FCPX? FCP7 on Lion will eventually break and it is probably third party cards and drivers that will show the strain first.
Dave Farrants
June 28, 2012 at 6:03 amNo solution as such, you do need to un-install older drivers before installing any new ones (uninstaller included in driver download). I have a similar system to you and never had/get any problems with my Intensity Pro, it’s used for HD and component monitoring and occasional input via composite or S. It is a clean machine – OS 10.7.4, FCS3 and a few other video/audio/photo progs and no permanent internet connection. (Not too far from you if you want to chat).
Web – https://www.foxvideo.co.uk
Blog – https://foxvidpro.blogspot.co.uk/ -
Ben Edwards
June 28, 2012 at 9:15 am“Are the latest drivers for FCP7 or FCPX? FCP7 on Lion will eventually break and it is probably third party cards and drivers that will show the strain first.”
Do you mean am I using the latest version of FCP 7, I have not come across FCP 7 drivers as such.
Ben
Ben Edwards
June 28, 2012 at 9:19 amThanks, do I also need to upgrade firmware?
Ben
Dave Farrants
June 28, 2012 at 10:27 amCurrent software/drivers will only install if you have the correct firmware. I don’t recall having to update FW for the past few versions of SW.
Ben Edwards
June 28, 2012 at 10:45 amThanks, had a look at site and the FW updates are built into Driver update.
Regards,
Ben—
Michael Gissing
June 28, 2012 at 11:50 pmNot sure about Decklink as I am using a Kona, but Kona has different drivers for FCPX to FCP7 so I was suggesting you make sure you have the correct Decklink drivers for your combination of OS and FCP.
