Activity Forums Blackmagic Design Intensity Pro Freeze using SDK
  • Intensity Pro Freeze using SDK
    Posted by Warren James on September 4, 2012 at 9:24 am
    Hello All,
    I am currently using the SDK to write some applications for testing products that have an HDMI output.
    I have a few different Blackmagic cards but the two I am using the most are the Intensity Pro and the Decklink Extreme 3D.
    For the application I would ideally like to use the Intensity Pro (mainly due to the cost difference!)
    To test the application I have introduced a fault to the HDMI being tested – namely some connections are not made on the connector.
    At this point the SDK does not produce any frames – so the VideoInputArrivedFrames callback does not trigger.
    I would think this totally normal behavior seen as there is a fault on the HDMI connector being tested but if I use the Decklink Extreme 3D a frame is produced – all be it with an error but this is a much more desirable and easy to work with symptom then the previous.
    I have updated the drivers and the SDK to the latest – Driver 9.6 SDK 9.5
    Any ideas of why this happens and if there is a way to get the Intensity Pro to behave like the Extreme 3D?
    Thanks in advance.
    Warren James replied 14 years ago 1 Member · 0 Replies
  • 0 Replies
