Activity Forums Blackmagic Design Intensity Pro/ CS5 & Multi-cam
  • Intensity Pro/ CS5 & Multi-cam
    Posted by Randy Johnson on August 27, 2010 at 7:13 pm
    I am starting to use CS5. I convert my footage over to DVCpro HD to edit. Everything seems to work fine except when I try and use multi-cam. I open the multi-cam window it looks fine until I hit play then it only shows one source streatched across the window and then many times it crashes. Anyone else with this issue?
    Randy Johnson
    Rando1968@comcast.net
    Randy Johnson replied 16 years ago 1 Member · 0 Replies
  • 0 Replies
