Activity Forums Blackmagic Design INTENSITY PRO confused about specs
  • INTENSITY PRO confused about specs
    Posted by Sebastian Toro on July 30, 2007 at 11:29 pm
    I am confussed about this:
    i didn’t found metions about analog HD input/output capabilties.
    is possible to capture HD via intensity pro analog component inputs?
    rent an HD deck and masterize with hd analog outs?
    if this is possible i think is a very cheap way… i don’t know if this kind of master is well enough…
    if no prores 422 avaliable, trough hd analog component or hdmi inputs, what codecs are? uncompressed HD?
    i heard apple guys said that you can capture prores 422 in the fly only if you have a macpro and not with old g5
    sorry about my english…
    sebastian toro –
    bs as argentina
    sinsistema.tv
    sebastian toro –
    sinsistema.tv
    Sebastian Toro replied 19 years, 1 month ago 2 Members · 2 Replies
  • Kristian Lam
    July 31, 2007 at 12:18 am
    [sinsistema] “is possible to capture HD via intensity pro analog component inputs?”
    Yes, Intensity Pro’s component inputs support 1080i HD.
    If you’re not using a supported Mac for ProRes capture, you can also capture to JPEG, DVCPRO HD or Uncompressed.
    regards
    Kristian Lam
    Blackmagic Design
  • Sebastian Toro
    July 31, 2007 at 1:13 am
    Thank you Kristian.
    What about capturing progresive from a panasonic dvx200?
    sebastian
