Activity › Forums › Apple Final Cut Pro Legacy › Intensity Pro card video synce problem
Posted by Robert Bec on June 1, 2009 at 11:53 amHey guys
I am working in FCP and i am viewing my work on a Sony bravia connected to a HDMI port
My problem is my canvas and bravia are out of sync
has anyone encounted this problem before
Please help
Regards
Robert
Andy Mees replied 17 years, 3 months ago 3 Members · 4 Replies -
Steve Oakley
June 2, 2009 at 4:58 amthats normal. there is about 4 frames of offset between the canvas and your video out. if you don’t like it, complain to apple… and see how far that gets you. 🙁
Robert Bec
June 2, 2009 at 5:35 amIS this with all products
I was using my Sony deck via firewire perfect now since i want to view HD and installed the card dissapointing
Steve Oakley
June 5, 2009 at 5:39 amwhen using any I/O card, or even Dv device , you should monitor your audio from there and it will be in sync to the video out picture from the same place. its just how fcp works.
Andy Mees
June 6, 2009 at 12:53 pmAs Steve has pointed out, this is perfectly normal … however, no need to “complain to apple” as suggested as they already include a specific control to compensate for such discrepancies:
Check in your Final Cut Pro menu > System Settings window, under the Playback Control tab, and there you will see a Frame Offset control with a default setting of 4 frames. Simply tweak this value for your particular setup .. you should be able to quickly discover the offset value which brings your Canvas and External Video device back into sync.
Cheers
Andy
