Activity › Forums › Blackmagic Design › Intensity Pro Capture…
  • Intensity Pro Capture…
    Posted by Greg Burke on January 23, 2012 at 5:35 am
    Hey all Im using the Intensty pro Card to capture Xbox footage into my Tower(MacPro)…However the lack of recording options puzzles me…
    The Format options are
    Apple Proress
    Uncompressed 8-bit
    DVCPRO HD
    My partner has a PC(windows) with the same setup but he has better capture options (H.264)) witch saves a huge amount of hard drive space, why don’t I have these options?
    I wear many hats.
    http://www.gregburkepost.com
    Etienne Mare replied 14 years ago 3 Members · 3 Replies
  • Joshua Helling
    January 23, 2012 at 9:21 pm
    Media Express can only capture h.264 if it is attached to a H.264 Pro Recorder or an ATEM TVStudio. These options will only be possible with the H.264 device connected. Then you need to select it from the device menu option.
    But the Intensity Pro by itself will not be able to do that. Both DVCPro HD and ProRes are very small footprint. DVCProHD is 100Mb/second 12.5MB/second. ProRes is a little higher around 18MB/second.
    Sincerely,
    Joshua
    Director of Support
    Blackmagic Design Inc.
  • Etienne Mare
    September 26, 2012 at 8:17 pm
    Hi
    I work on a quad core mac pro, with intensity pro installed. Would the H264 Pro Recorder be of any benefit if i want to stream live?
    Etienne
  • Etienne Mare
    September 26, 2012 at 9:10 pm
    Hi Joshua
    Just another quick question: Jan Ozer (streamingmedia) reports that he experienced problems with 16:9 SD footage thru the H264 Pro Recorder
    quote:
    When I tested native encoding of 1080p footage, both the resolution and aspect ratio were correct. When I encoded 4:3 SD footage, the Pro Recorder produced the video at 720×480 resolution at a pixel aspect ratio of 1.0, rather than the required .9091, which made the footage about 10 percent fatter than it should be. With 16:9 footage, the encoded file was still 720×480 with a pixel aspect ratio of 1.0, rather than 1.2121, making the video look too skinny. This was so even after I checked the Use Anamorphic SD 16:9 option in the Pro Recorder preferences dialog
    Has this issue been addressed and sorted out?
    Regards
