Activity Forums Blackmagic Design intensity pro AVID mc 6.5
  • intensity pro AVID mc 6.5
    Posted by Rob Tobin on July 16, 2013 at 6:17 pm
    Hello,
    I would like confirmation from anyone using MC 6.5 and an intensity pro card that it CAN NOT IN FACT
    PLAYBACK 23.98. Just build a brand new 3.33 6-core 10.8.3 MC 6.5.3 hoping to use HDMI as a monitor
    (monitor only system have SDI for grading)
    After much investigation… I believe although AVID labels it as “P” they really output “Psf” which is not
    supported via HDMI. This doesn’t explain why it does not work component out. Both Blackmagic and AVID
    claim this card is supported. It does work with FCP as a cross convert to 59.94. I see they offer a deckling
    mini monitor that supports Psf but I would image it is only via SDI and then would need a SDI to HDMI converter.
    I have two other systems running AVID and AJA cards that do this conversion via SDI.
    ANYONE ELSE?
    Rob Tobin replied 13 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
