Activity › Forums › Blackmagic Design › Intensity Pro and Windows 7
Posted by Randy Johnson on May 30, 2009 at 7:20 pmI need to reinstall my system I currently use VISTA 64, I REALLY like Windows 7 and have the latest beta from MS. Id like to just install this and buy it when it come retail will the Intensity Pro work with it?
Kevin Hodgins replied 16 years, 9 months ago 5 Members · 7 Replies -
Marc Sparks
May 30, 2009 at 7:49 pmI don’t have an Intensity, but I can tell you that in my Windows 7 experiments, the only thing I haven’t been able to make work were a few peripherals that wouldn’t work with Vista 64 either. (The problem was the lack of x64 drivers, not the OS.)
I’ve even run a few pieces of software that I really expected to have to run in Virtual XP mode, or not at all, such as Lightwave 7, which uses a dongle for security. In fact, I think it wasn’t working in Virtual XP mode, but I got it working fine in Win 7.
That doesn’t mean your Intensity will work right out of the box, but it’s certainly worth a try. It seems to me that the jump from Vista to 7 isn’t a huge leap, and if there are any problems, they will probably get fixed easily. It’s not like switching from XP to Vista, or from CS3 to CS4, which had major hurdles.
Margus Voll
June 1, 2009 at 1:13 pmHi.
From my experience W7 is not solid enough to use i production.
I have RC at home and i tends to give blue screen etc. so i would not
rely on it when working with deadlines and client.—
Margus
Randy Johnson
June 1, 2009 at 2:05 pmREALLY?? I am running Windows 7 RC on one of my machines and its MUCH more stable than VISTA. I edit on it with Edius and Premiere I just dont have a BM card in it.
Randy Johnson
Rando1968@comcast.net -
Margus Voll
June 4, 2009 at 10:39 amI do not have this solid experience yet as i have to BOOT my win 7 time to time. My old XP and Mac OS are more solid compared to that.
Margus
Nathan Goodfellow
October 2, 2009 at 7:31 pmHave you had a chance to test the Intensity Pro with Windows 7 yet? I’m currently having issues, so far I can’t get anything to record or display. Is this a known issue? I used windows 7 and plan on continuing to use it when it comes out, I would hate to have to downgrade because of a hardware issue. I’m also not sure if its a faulty card because I have only tested it on my windows 7 machine.
Nate
http://www.softthoughts.info -
Kevin Hodgins
December 23, 2009 at 6:35 amIm having the same problem and i have the full windows 7 ultimate and i have intensity pro, so far i cant get anything to work. Ive done all the updates and everything and so far…. nuffin =(
Kevin Hodgins
December 24, 2009 at 3:14 amSo far.. no, it doesnt work for me and i have the full version. They say there is compatible drivers and softwre but so far, they dont work.
