Activity › Forums › Apple Final Cut Pro Legacy › Intensity Pro and so
  • Intensity Pro and so
    Posted by Tielman Dewaele on February 16, 2008 at 4:52 pm
    Hey,
    I bought the intensity Pro card and a Eizo Flexscan HD2411 Lcd TV for my HD project, that works fine for me.
    However i got still SD projects going on sometimes…
    I know it is possible to view SD on a HDTV(trought HDMI), but it gets scaled and quality is poor.
    I was wandering if i can connect a simple (non-flatscreen) tv, because i cant effort a Jvc monitor or something else, for SD editing.
    Yes? how do i connect it?
    I dont now much of this things.
    MrT.
    Kevin Monahan replied 18 years, 7 months ago 2 Members · 5 Replies
  • Kevin Monahan
    February 16, 2008 at 4:58 pm
    Connect it through your deck or camcorder FireWire > Deck > TV via composite cables (RCA) or S-Video.
    Kevin Monahan
    Take My FCP Master’s Workshop!
    fcpworld.com
    Pres. SF Cutters
  • Tielman Dewaele
    February 17, 2008 at 7:38 pm
    So there is no way to do this via the intensity card?
    Because i dont have a deck and not a camera at the moment.
    I dont have a deck because they diliver most of the stuff on external discs.
    T
  • Kevin Monahan
    February 17, 2008 at 8:32 pm
    Hi Wally,
    The Intensity Card comes with a breakout cable, so you could use that for analog monitoring.
    From the website: https://www.blackmagic-design.com/products/intensity/
    Highest Quality Analog Connections
    The included break-out cable connects Intensity Pro to all types of analog video and audio equipment. This gives you full compatibility with analog component, NTSC, PAL, S-Video and analog audio.
    Kevin Monahan
    fcpworld.com
    Pres. SF Cutters
  • Tielman Dewaele
    February 17, 2008 at 8:52 pm
    Ok thank you Kevin.
    So what cable exactly do i need to get for the tv(lets say a sony 4/3 tv) and to which one go’s were in the breakout cable?
    Is the quality be ok?
    Same for a SD monitor(for example SONY PVM or so)
    It for previewing DV, DV-CAM, XD-CAM footage to be more clear..
    T.
  • Kevin Monahan
    February 17, 2008 at 9:10 pm
    I’d use the RGB component connections if you have them on your broadcast monitor, S-Video secondarily. I use S-Video when using DV NTSC, since my DV deck doesn’t have component out. If it’s a cheap TV, you might try the S-Video connector. Composite video as a last result. For audio, looks like you’ve got RCA. If you don’t know which cables are which, consult the manual. You can probably figure it out though.
    Kevin Monahan
    fcpworld.com
    Pres. SF Cutters
