Activity Forums Blackmagic Design Intensity Pro
  • Intensity Pro
    Posted by John Reis on November 2, 2010 at 4:55 pm
    OS 10.5.8
    2×2,8 GHZ Quad-Core Intel Xeon
    12 GB 800 MHZ DDR FB-Dimm
    So I purchased the Intensity Pro, In order to have an HD YUV signal going out to my monitor (Panasonic BT-LH1710) and I get no signal. Not evem a flicker when I switch thru the many output settings.
    Does all my media have to be in the BlackMagic Codec? Sequence is Apple Pro Res 422 23.98fps.
    Salesman told me this thing was great 2 weeks ago. Yesterday I went back, and I got “I dont know Ive never used it”.
    Wishing I bought a Matrox.
    Bob Haber replied 15 years, 10 months ago 3 Members · 5 Replies
  • Kristian Lam
    November 3, 2010 at 6:57 am
    ProRes playback is fine. Are you using the Blackmagic easy setups in Final Cut Pro to configure your project?
    regards
    Kristian Lam
    Blackmagic Design
  • John Reis
    November 3, 2010 at 1:53 pm
    Yes, I have used the easy set ups. Is there an easy test you can suggest? Id like to just se if it works, and get some kind of signal thru.
  • Bob Haber
    November 3, 2010 at 11:55 pm
    Is your motherboard based on an X58 northbridge? The Intensity PCI-e cards don’t work with the X58.
  • John Reis
    November 5, 2010 at 4:01 am
    How do I tell what sort of motherboard I have?
  • Bob Haber
    November 5, 2010 at 11:18 pm
    On a PC, it would be displayed at the start of bootup (possibly you’d have to press a key to see the text startup sequence instead of some logo) but on a Mac I really have no idea, sorry.
