Activity Forums Blackmagic Design Intensity Pro
  • Intensity Pro
    Posted by Jose Burgos on April 2, 2010 at 5:52 pm
    Is there a way to use the card for HMDI in and SD analog out in real-time? I can do HDMI to Analog Component at HD resolution works but I am trying to get it to output to SD resolution it any analog format.
    Thanks in advance,
    Jose Burgos
    http://www.burgosfx.com
    Jose Burgos replied 16 years, 5 months ago 2 Members · 2 Replies
  • Kristian Lam
    April 3, 2010 at 10:19 am
    Hi
    Not while you’re capturing. But if you’re playing back a HD clip, you can able down conversion in the Blackmagic preference pane to get SD output.
    regards
    Kristian Lam
    Blackmagic Design
  • Jose Burgos
    April 3, 2010 at 2:14 pm
    Yeah on playback every possibility works but I was hoping for real time to use it as a scan converter for computer display in to SD out. I guess I can upgrade my TriCaster to an XD300 or purchase a scan converter if this is the way I need to go.
    Was hoping one of you BMD gurus had a trick up your sleeve 🙂
    Thank you and Take care,
    Jose Burgos
