Activity Forums Blackmagic Design Intensity Pro 3.5.1 Drivers issue
  • Intensity Pro 3.5.1 Drivers issue
    Posted by Steven Lynas on January 19, 2010 at 1:12 pm
    Hi All,
    I’ve got an Intensity Pro running on the following PC;
    Time of this report: 1/18/2010, 17:00:58
    Machine name: PHENOM-64
    Operating System: Windows 7 Enterprise 64-bit (6.1, Build 7600) (7600.win7_rtm.090713-1255)
    Language: English (Regional Setting: English)
    System Manufacturer: Gigabyte Technology Co., Ltd.
    System Model: GA-MA790FX-DQ6
    BIOS: Award Modular BIOS v6.00PG
    Processor: AMD Phenom(tm) II X4 965 Processor (4 CPUs), ~3.4GHz
    Memory: 8192MB RAM
    Available OS Memory: 8190MB RAM
    Page File: 1425MB used, 14954MB available
    Windows Dir: C:\Windows
    DirectX Version: DirectX 11
    DX Setup Parameters: Not found
    User DPI Setting: Using System DPI
    System DPI Setting: 96 DPI (100 percent)
    DWM DPI Scaling: Disabled
    DxDiag Version: 6.01.7600.16385 32bit Unicode
    Card name: NVIDIA GeForce 9600 GT (Microsoft Corporation – WDDM v1.1)
    Manufacturer: NVIDIA
    Chip type: GeForce 9600 GT
    DAC type: Integrated RAMDAC
    Device Key: Enum\PCI\VEN_10DE&DEV_0622&SUBSYS_34811458&REV_A1
    Display Memory: 4080 MB
    Dedicated Memory: 497 MB
    Shared Memory: 3582 MB
    Current Mode: 1680 x 1050 (32 bit) (59Hz)
    Monitor Name: HP w2207 Wide LCD Monitor
    Monitor Model: HP w2207
    Monitor Id: HWP26A8
    Native Mode: 1680 x 1050(p) (59.954Hz)
    Output Type: HD15
    Driver Name: nvd3dumx.dll,nvd3dum,nvwgf2umx.dll, nvwgf2um
    Driver File Version: 8.15.0011.8593 (English)
    Driver Version: 8.15.11.8593
    DDI Version: 10
    Driver Model: WDDM 1.1
    Driver Attributes: Final Retail
    Driver Date/Size: 7/14/2009 01:41:53, 9443840 bytes
    When I upgrade from 3.4 to 3.5.1, the card stops talking to software.
    Only when I downgrade to 3.4 again will it work. Any ideas? I know a bit about these cards, but not enough to know why it’s not working after an upgrade (Note that the firmware on card is upgraded / downgraded depending on which way I go!)
    I’m at my wits end.
    Kyle Bond replied 16 years, 3 months ago 4 Members · 5 Replies
  • Johan Zwaan
    January 22, 2010 at 2:09 pm
    I’m also having problems with this driver but on my Mac Pro with FCP 6.0.6. Since I installed the new driver I’m only getting “Video Not Supported’ on my monitor.
    It used to be fine but I was dumn enough to delete the old driver…
    BM is supposed to have an archive for older drivers, but I can’t find it.
    I would REALLY like some help with this and already mailed BM Support about this.
    anyone here any idea?
  • Johan Zwaan
    January 22, 2010 at 4:07 pm
    Update:
    I did find the drivers-archive but 3.3.2 isn’t working either!
    It’s only outputting “Video Not Supported”. What is this?!
  • William Buchanan
    February 10, 2010 at 1:55 pm
    I too experienced problems with the new driver… I reverted back to the 3.5 which was working flawlessly. I’m using a 2.8 OctoCore Mac. I went through all of the normal fundamentals trying to get 3.5.1 to work but finally gave up. I suppose it’s ok to share drivers… shoot me an e-mail and I’ll send you the 3.5 driver for Mac as it is only 8.5 megs. Good luck in the meantime!
  • Johan Zwaan
    February 22, 2010 at 10:01 am
    Hi William,
    Thanks for your offer and sorry I didn’t reply earlier…
    Shortly after my last update (january 22nd) I tried going back to driver 3.3.2 again. After reboot update to 3.5.1 was suggested (again) by Blackmagic Updater so I did and then… Everything finally worked. I’m 100 % sure I tried this before and more than once, but anyway. It works.
    Strangely enough, after that I noticed several preferences were gone on my MacPro and not only in FCP. Weird, but since it’s not too serious I try to ignore it!
    good luck there and try to ‘downdate’ once more…
  • Kyle Bond
    June 9, 2010 at 9:31 pm
    any chance i could get that driver for the Mac. nto sure waht happened- guess i upgraded and everything is shot. wish i backed up the old driver…
    thanks
    creativebond (@) gmail . com
