Activity Forums Blackmagic Design Intensity Pro
  • Intensity Pro
    Posted by Adrian Fox on February 11, 2012 at 1:12 am
    I’m thinking about getting a Blackmagic Intensity Pro to record my video games, I currently use a Hauppauge HD PVR and have been for around two years or so, but I want to use HDMI for a better playing experience and I’m obsessed with video quality and the Hauppauge doesn’t produce the pixel perfect quality I would like to have, I assume due to the low 13.5 Mbps bitrate compression, anyway, I just want to make sure my PC will be able to run it comfortably first and their website is very vague on the requirements now, so here are my specs :
    Operating System : Windows 7 64 bit
    CPU : AMD Athlon II X4 635 (Quadcore / 2.90GHz)
    RAM : 4.00 GB
    Graphics card : NVIDIA GeForce 9500 GT (1GB / OpenGL 2.1)
    Hard disk : 500GB (425GB free, I understand recording uncompressed produces massive file sizes so I may need to purchase an external drive, in the mean time I could record in a compressed format if needed)
    I’m fairly sure this system should be able to run it comfortably, but I just want to be sure before I shell out for a capture card I can’t use, also if I am going to need to buy an external HDD, can anyone recommend one for me? I don’t have a huge budget so preferably something cheap ; )
    Thanks for any help.
    Justin Moy replied 14 years, 7 months ago 2 Members · 1 Reply
  • Justin Moy
    February 14, 2012 at 2:05 am
    I can’t see any issues with your system. Should be compatible.
    However, you cannot capture uncompressed HD footage to a single, mechanical hard drive.
    Instead, you’d probably want to capture in Motion JPEG, which has a variable bit rate of ~70-150 mbits/s (non-selectable). 1 minute will equate to 1 GB on average. This can be selected in the included Media Express applitcation so nothing else is required.
