Activity › Forums › Blackmagic Design › Intensity Pro
Intensity Pro
Posted by Lachlan Jadezak on December 12, 2010 at 7:39 amThe Black magic support isn’t working for me, so I’m hoping some one here could give me an answer.
I’ve heard the Intensity Pro has compatibility issues with the i7 series. True or false? I have an i7 860 and I’m really hoping it works 😐
Bob Haber replied 15 years, 9 months ago 6 Members · 7 Replies -
Lachlan Jadezak
December 13, 2010 at 1:36 amOk thank you very much! Any other confirmations welcome 🙂
Edison Nguyen
December 13, 2010 at 5:32 amI can confirm as well…works great with the i7, both Intensity Pro and Intensity Shuttle 🙂
Lachlan Jadezak
December 13, 2010 at 5:44 amOk thank you very much! Shall be buying one 🙂
Oh one last thing, you can have component in and HDMI out right? My monitor doesn’t have component in, and I can’t have HDMI in to the intensity as I’ll be using a PS3 which has HDCP encoding, so I want to have component in to the card from the PS3 and then HDMI out to the monitor.
Thanks.
Danny Hays
December 13, 2010 at 7:37 pmPlease do your homework before buying the motherboard if you’re getting the Shuttle. It needs an X58 or P55 chipset and a fast enough USB 3 port. Asus P6X58D-Premium or -E both work. Danny Hays
Joshua Helling
December 13, 2010 at 9:54 pmThis combination should be fine. Some of the original X58 chipsets (the 1.0 revs) had problems with our 1x lane PCI express boards (including Intensity Pro) but this situation was corrected by intel a while back.
Sincerely,
Joshua
Director of Support
Blackmagic Design Inc. -
Bob Haber
December 18, 2010 at 11:04 pmCan you provide any way to determine if a given X58 motherboard will be compatible or not? Or is it something that is fixable with a BIOS update?
