Activity Forums Blackmagic Design Intensity output preview on Dell 2407WFP
  • Intensity output preview on Dell 2407WFP
    Posted by Walterdr on February 8, 2007 at 3:03 pm
    I have a simple question.
    Can I use my Dell 2407WFP as preview monitor
    whit Intensity, using a HDMI/DVI cable??
    And if yes, can I see only in HD resolution or in SD pal too??
    I’ll lose audio but the quality will be the same, I suppose.
    Thx so much and sry for my english!!
    Walterdr replied 19 years, 7 months ago 3 Members · 5 Replies
  • Kristian Lam
    February 13, 2007 at 5:54 am
    Sorry, this will not work.
    regards
    Kristian Lam
    Blackmagic Design
  • Joedully
    February 13, 2007 at 7:15 am
    Kristian, Could you please elaborate as I was planning on doing this with the Intensity as well. I am currently using an Abit motherboard with onboard HDMI 1.2 out to a 24″ Dell monitor at 1920×1600 and it works fine. This system is however not the one that I am installing the Intensity into.
    I am installing the Intensity into an Abit 680I motherboard and I was hoping to use one of the new 2407WFPs that I just purchased.
    Thanks – Joe
  • Kristian Lam
    February 13, 2007 at 7:21 am
    Hi Joe,
    Couple of factors:
    1) Intensity outputs YUV not RGB. Your Dell or any computer monitor will expect an RGB signals via DVI-D.
    2) Intensity does not adjust the framerate of the video to what is expected by the monitor unlike the HDLink.
    regards
    Kristian Lam
    Blackmagic Design
  • Joedully
    February 13, 2007 at 9:06 am
    So what is a suggested inexpensive monitor for the Intensity?
    Thanks – Joe
  • Walterdr
    February 13, 2007 at 1:04 pm
    Thx to all for reply.
    What kind of monitor or LCD/TV I need??
    Can I use a tv whit 1366*768 resolution.
    For now I work on sd footage at 576i
    but I’m planning to use the 720i too.
    And another question, if I use a 720i lcd tv
    what appened when I work in 576i??
    Thx again.
