Activity › Forums › Blackmagic Design › Intensity HD up-res vs FCP, others?
  • Intensity HD up-res vs FCP, others?
    Posted by Nick Meyers on March 29, 2008 at 12:22 am
    capturing archival from a non-controllable SD analogue source,
    cutting SD in FCP (HDV captured as DV),
    and our delivery format is HD.
    i figured i’d capture as HD, up-resing thru the intensity.
    then half way thru, the capture settings were accidentally changed to SD (groan!).
    im after an opinion on the quality of the Intensity up-res vs other post options.
    my simplest option is to just let FCP do the up-res in the timeline.
    other options include media managing the edited sections, and using Instant HD,
    or sending them to a post house to put thru a box.
    re-capturing is an option, of course.
    thanks,
    nick
    Nick Meyers replied 18 years, 6 months ago 1 Member · 1 Reply
  • Nick Meyers
    April 1, 2008 at 2:27 pm
    unexpected results!
    i did a quick test, and the FCP upres is clearly better than the Intensity one.
    (timeline set to best quality motion scaling)
    the image is sharper, plus the Intensity up-res adds a colour cast.
    so that makes life a bit easier…
    i’ve got Instant HD, so maybe i’ll test that when it;s all over.
    i’ll still be using Intensity to capture, but just to ProRres PAL
    much easier to work with.
    thanks,
    nick
