Activity Forums Blackmagic Design Intensity Drivers BSOD Frequently – Windows 7 Pro 64bit
  • Intensity Drivers BSOD Frequently – Windows 7 Pro 64bit
    Posted by Lawrence Jones on April 16, 2011 at 5:49 pm
    I had been getting blue screens every few days after installing my Intensity Pro into a new PC and after some research I tracked it down to the Intensity drivers. I tried 4 different revisions including the latest (3.9.4) but the crashes still occurred. I’ve since uninstalled the drivers and had no problems but not being able to use the card isn’t the ideal solution…
    From the amount of posts around the web this is a fairly common problem with Windows 7 64bit but I’ve never seen a solution given.
    Does anyone have the Intensity Pro working with Windows 7 Pro 64 and what drivers are you using? I’ve sent an email off to Blackmagic Design but the last time I had to contact them around a year ago it took 2 months before I received a pretty unhelpful reply.
    Lawrence
    George Sey replied 15 years, 4 months ago 4 Members · 4 Replies
  • Danny Hays
    April 17, 2011 at 12:53 am
    I would uninstall all BlackMagic accociated programs, Remove the card from the computer, Delete all Blackmagic folders from your program files directory, try it in a different slot on your motherboard. I have the Shuttle, with the same software and have never had a bluescreen issue with it. I’m on Win ulltimate 64 bit. I also monitor this forum and don’t recall Win 7 64 bit ussues with that card. If it has the same problem in a different slot, I’d send it back for a replacement.
  • Lawrence Jones
    April 17, 2011 at 2:15 am
    Doesn’t the shuttle use different drivers? I’ve been running this card fine with Vista 32bit for almost a year after sending my first one back due to audio issues. Every result I looked at about Intensity drivers blue screening with process_has_locked_pages and driver_power_state_failure were all from Windows 7 64 users, although it could be coincidental of course.
    Unfortunately my card is a few months out of warranty so I’d be more inclined to look for alternatives rather than take a chance on a third one.
  • Scott Francis
    April 17, 2011 at 3:32 am
    I have one Intensity card in my PC…worked fine…but DID have some issues when I first installed it, changing the PCIe slot did the trick…I would try that..Windows 7 64 but Ultimate is running it fine!
    Scott
    Scott Francis
    Mind’s Eye Audio/Video Productions
  • George Sey
    April 17, 2011 at 5:32 am
    Have three systems running intensity and windows 7 on ASUS and they work with PPro 3, 4, 5 on same machine no problem
