Activity Forums Blackmagic Design Intensity driver request
  • Intensity driver request
    Posted by Alan Okey on April 14, 2010 at 5:08 pm
    Here’s something that would be a real benefit to the Intensity driver:
    When using the Intensity’s SD downconversion mode in Final Cut Pro, it would be great if Intensity would automatically shift 720×480 footage up or down one pixel to maintain proper field order when playing out NTSC (720×486) via the component analog outputs. AJA Kona cards do this, while Intensity does not.
    Currently, the only way I can get a DV (720×480) resolution video to play back with the proper field order is to nest it in a 720×486 sequence. This is cumbersome and unnecessary.
    Alan Okey replied 16 years, 5 months ago 1 Member · 3 Replies
  • Alan Okey
    April 16, 2010 at 3:53 pm
    Update:
    I just updated to the latest driver and this issue has been corrected.
  • Alan Okey
    April 16, 2010 at 8:26 pm
    Another update:
    After a Pro App update and a restart, the field order on 720×480 sources is wrong again. Reinstalling the latest driver again didn’t help.
  • Alan Okey
    April 24, 2010 at 12:55 am
    Hopefully the final update:
    After powering off the system, the field order has subsequently been correct for 720×480 material displayed using the 720×486 output setting, so apparently the required field shift is being applied.
