Activity Forums Blackmagic Design Intensity Card Photoshop Video Preview
  • Intensity Card Photoshop Video Preview
    Posted by Nathan Moss on August 13, 2008 at 3:33 pm
    My Intensity Card is working properly in After Effects CS3 and Premiere Pro CS3, but it is not being recognized in Photoshop CS3. If I try to do a Video Preview, it simply says that there isn’t a device detected. I have updated the Black Magic drivers. Does anyone have any ideas or thoughts on fixing this? Thanks.
    Callum Mclay replied 18 years ago 2 Members · 1 Reply
  • Callum Mclay
    August 14, 2008 at 2:32 pm
    Hi Nathan
    What might be happening here is that you are actually selecting the wrong output option in the export menu. To see your Photoshop file on screen via your Intensity, you need to select File>>Export>>Blackmagic image export and this will send your still frame to the screen. When you hit this option, you will have to select a resolution and output channel that matches your image, to display correctly.
    To update your output each time you make a change to your image, just use the Export>>blackmagic option again. It may be worth binding this action to a hot key using the actions pallete.
    If you use the send video preview option, you will get a device not found error. Hope this helps!
    Callum McLay
    Technical Support Consultant
    Blackmagic Design EMEA
