Activity › Forums › Compression Techniques › Intel Indeo 3 AVI file need to be able to convert to a format that will play
  • Intel Indeo 3 AVI file need to be able to convert to a format that will play
    Posted by Geoff Edwards on August 2, 2014 at 7:54 pm
    Hi I have several short AVI videos recorded as Indeo 3 which I understand has been discontinued. I need advice as to how to convert these files to MP4 (I think that is the appropriate format)
    Thanks Geoff
    Geoff Edwards replied 11 years, 11 months ago 2 Members · 2 Replies
  • Craig Seeman
    August 4, 2014 at 3:39 pm
    You could try converting it in VLC although there might be a better way.
    There’s always the “cheat.” If you can play the file you can capture it with a good screen grabbing program and convert it that way.
  • Geoff Edwards
    November 1, 2014 at 12:49 pm
    Thanks Craig VLC works 🙂
