  • Posted by William Bearden on May 15, 2006 at 8:53 pm
    I want to set up a simple and portable edit system for my weekend/vacation home. I will not be doing any high end work…only DV and stills level editing for local public TV documentaries and freebies we do for non-profits. I want to get a 17″ intel iMac, an additional 17″ LCD for a second monitor, and a two-drive Firewire bay with removable drives. Question:
    Do I need to buy new FCP software? (we own two copies of FCP Studio)
    How do I upgrade?
    Will this system do what I need it to do?
    William Bearden/Memphis
    Jeff Carpenter replied 20 years, 4 months ago 3 Members · 2 Replies
  • Jerry Hofmann
    May 15, 2006 at 9:34 pm
    I should think it will work great for DV and with the FW drive setup for media storage. As far as the licenses go, as long as you only install one license per each desktop computer you are legal… i.e., you aren’t legal if you install on a third desktop machine.
    Jerry
  • Jeff Carpenter
    May 15, 2006 at 10:43 pm
    How much is that 2nd monitor gonna cost you? The 20″ iMac is only $400 more and you wouln’t need a 2nd monitor. Probably easier to carry around than a dual-monitor setup. I’ve got a 20″ and the screen is fantastic. For the kind of work you’re describing I can’t imagine you’ll have any trouble using that and that alone.
    Not to mention that the $400 will get you a faster processor as part of that price.
    But yes, the iMac will make you happy. I’ve been using mine to do multi-cam DV editing and it’s done very well. IF you get the 20″ I suggest upgrading the video card ($75), the RAM to a 1 GB chip ($100), and another 1 GB chips from crucial.com ($189). You can do without the video upgrade if you want to save money but you should get at least 1 GB of RAM at a minimum.
    To expand on what Jerry said, you’re going to need the Universal version of Final Cut. You’ll either have to buy a fresh copy (so, a 3rd for you) or pay $50 to crossgrade one of your current ones. That involves sending Apple the discs and you’d have to take it off of one of your other computers. So long as you do that part it’s perfectly ok, however. Search Apple’s website for “Final Cut Crossgrade”.
    Also, if you’re gonna be traveling, you should get a case for the computer:
    https://eshop.macsales.com/item/LTA%20Projects/851236001091/
