Activity Forums Adobe Premiere Pro Intel Core 2 Quad – Q6600 and Premiere Pro 2.0
  • Intel Core 2 Quad – Q6600 and Premiere Pro 2.0
    Posted by Clyde Villegas on April 16, 2008 at 11:47 pm
    I’m planning to upgrade to an Intel Core 2 Quad – Q6600. Can Premiere Pro 2.0 use all cores on this processor? Can it handle DVCPRO-HD easily? Thanks and God bless.
    Clyde Villegas replied 18 years, 5 months ago 3 Members · 6 Replies
  • Harm Millaard
    April 17, 2008 at 10:14 am
    CS3 would be the better choice.
    Harm Millaard
  • Clyde Villegas
    April 17, 2008 at 10:40 am
    Thanks Harm. You mean the 4 cores won’t work on Premiere Pro 2.0? God bless.
  • Harm Millaard
    April 17, 2008 at 12:07 pm
    2.0 is not optimized for multi-core, CS3 is and supports up to 16 cores. However, this does not yet apply across the board, some parts are still limited in multi-core support, but that improves with every new patch or point release. 2.0 is no longer improved on.
    Harm Millaard
  • Clyde Villegas
    April 17, 2008 at 10:28 pm
    Ok. That means until I get the new CS3, there’s no point in buying multi-cores. Thanks Harm.
  • Marcio Pinto
    April 18, 2008 at 8:32 pm
    Check some benchmarks here:
    https://www.tomshardware.com/charts/cpu-charts-2007/premiere-pro-2-0,386.html
    Select/hide the processors you want to compare, and choose the benchmark from the menu. It’s good stuff.
  • Clyde Villegas
    April 19, 2008 at 7:39 am
    Thanks Marcio!
