Activity Forums Apple Final Cut Pro Legacy Integrating NTSC material into HD DVCPRO project
  • Integrating NTSC material into HD DVCPRO project
    Posted by Philip Owens on August 8, 2005 at 9:54 pm
    I’m doing an HD DVCPRO (960x720p 24fps) project and will need to cut in some NTSC material. Adding the NTSC clips directly to the FCP sequence and rendering showed bad interlacing and reverse telecine problems, i.e. ‘scan-liney’ torns edges on fast moving objects and jerky motion. What is the best approach? Are there plug-ins for this?
    Philip Owens replied 21 years, 1 month ago 3 Members · 3 Replies
  • Graeme Nattress
    August 9, 2005 at 12:08 am
    Check out my Standards Conversion plugin http://www.nattress.com which will do a nice 60i to 24p conversion for you.
    Graeme
    http://www.nattress.com – Film Effects and Standards Conversion for FCP
  • Kevin Monahan
    August 9, 2005 at 8:37 pm
    Are you scaling up the NTSC clips from D1 to DVCPRO HD? If so, don’t expect the quality to be great. I think it’s better to downconvert the HD to D1 size.
    Kevin Monahan
    Author – Motion Graphics and Effects in Final Cut Pro
    fcpworld.com
  • Philip Owens
    August 10, 2005 at 1:16 am
    Unfortunately, yes. It’s an HD-finish project, with NTSC elements, so sadly I can’t do as you recommend and scale down the HD.
