Activity Forums Apple Final Cut Pro Legacy Integrating DVD clips into Documentary
  • Integrating DVD clips into Documentary
    Posted by Milton Ginsberg on June 18, 2013 at 7:10 pm
    I’m making a doc combining public domain movies off dvds with live action (avchd).
    Of course I need optimum quality so please be so kind as to comment on my flowchart:
    Timeline in FCP7: prores 422 / 1920×1080 / 23.98 fps
    Using HANDBRAKE off dvd > High Qual H264
    Then MPEG Streamclip — Prores 422 @ 108i
    (rather than 720p or unscaled — Do I want to de-interlace?)
    Then restoring image to original shape using motion in FCP7.
    (Also, using FCPX to convert out of camera AVCHD material to MOV. > FCP7)
    Thank you, mmg
    Milton Ginsberg replied 13 years, 3 months ago 3 Members · 4 Replies
  • Mark Suszko
    June 18, 2013 at 7:51 pm
    Streamclip already does what Handbrake does, doesn’t it? Why are you converting twice?
  • Milton Ginsberg
    June 18, 2013 at 8:13 pm
    Streamclip converts some of these files, but not all.
  • Shane Ross
    June 18, 2013 at 9:12 pm
    Use COmpressor to upscale and convert the files you rip as H.264s. Turn on the FRAME CONTROLS and set them to BEST. COnvert the frame rate there too. I had to do this a few times in my career…two projects in the last month alone.
    Shane
    Little Frog Post
  • Milton Ginsberg
    June 19, 2013 at 2:25 pm
    Thanks Shane, I’ll give it a try.
    What frame rate do you recommend, 23.98 or 29.
    from FCP7 timeline on down?
