Activity Forums Boris FX Insuffieient Memory problem with Graffiti
  • Insuffieient Memory problem with Graffiti
    Posted by Jim Kaye on September 8, 2008 at 5:16 pm
    I am using Graffiti and FX on Vegas 8.0. In a project I applied several animated titles using Graffiti. When I render the project I get a Graffiti error box stating ” insufficient memory”. I tried increasing the preview buffer size in Graffiti to 1.5 gb and turning off Open GL. No change. My system has 4 gb memory (rendering shows useage of no more than 1.7 gb total) with quad 2.6 gb processor. Anyone seen this error before? Any ideas how to fix it? It is not a fatal error. I can click ok numerous times but it is bery time consuming.
    Jim
    Peter Mcauley replied 18 years ago 2 Members · 3 Replies
  • Peter Mcauley
    September 8, 2008 at 7:48 pm
    Are you using the latest version of Graffiti and FX?
    Peter.
  • Jim Kaye
    September 9, 2008 at 4:43 pm
    Graffiti is 5.1 and FX is 9.1. Are these still current?
    Jim
  • Peter Mcauley
    September 10, 2008 at 12:44 pm
    They are indeed the current versions of the software. I suggest that you send an email to the support group at support@borisx.com explaining the situation. They should be able to resolve this issue for you.
    Cheers,
    Peter.
