Activity › Forums › Adobe After Effects › Insufficient RAM for multiprocessing
  • Insufficient RAM for multiprocessing
    Posted by Marc Yap on March 20, 2013 at 4:07 pm
    My AE cs5.5 says I have insufficient ram for multiprocessing when I try to do a ram preview .. I am running 8core AMD cpu and 32gb of ram .. my OS is win7 64bit .. It says that my actual cpus being used is 0 in the multiprocessing setup.
    Roland R. kahlenberg replied 13 years, 6 months ago 3 Members · 9 Replies
  • 9 Replies
  • Todd Kopriva
    March 20, 2013 at 9:27 pm
    That’s odd.
    Try resetting you preferences to defaults and quitting all other applications, and then try again.
    After Effects team blog
  • Marc Yap
    March 20, 2013 at 10:33 pm
    This does not work
  • Marc Yap
    March 20, 2013 at 10:59 pm
    Okay, I solved the problem by updating my graphics card drivers .. weird ..
    Thanks for your time
  • Marc Yap
    March 20, 2013 at 11:19 pm
    Oh gosh, sorry for this but after closing AE and re-opening up AE again with a current project i’m working on .. still the same issue
  • Roland R. kahlenberg
    March 21, 2013 at 1:08 am
    Try setting 8GB for other apps.
    HTH
    RoRK
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Imagineer Systems (mocha) Certified Instructor
    & Adobe After Effects ACE/ACI (version 7)
  • Marc Yap
    March 21, 2013 at 2:01 am
    No matter what I set it to it still doesn’t change .. actual cpus used stays at 0
    March 21, 2013 at 3:00 am
    Have you tried –
    * Rebooting
    * Opening other AEPs?
    * Trashing AE Prefs?
    RoRK
  • Marc Yap
    March 21, 2013 at 4:45 am
    I opened up AE blank without a project .. and it works .. what could be the problem why it doesn’t work on my current project? The comp is at 720p
    March 21, 2013 at 6:55 am
    It’s a quirky situation as far as I know. But there’s certainly something in the AEP that’s causing this issue. Plugins etc are of course a primary candidate.
    More info on MP here –
    https://helpx.adobe.com/after-effects/using/memory-storage.html
    HTH
    RoRK
