Activity Forums DaVinci Resolve “Insufficient memory (4095 MB) to allocate 4000 buffers on site 1.”
  • “Insufficient memory (4095 MB) to allocate 4000 buffers on site 1.”
    Posted by Nick Anderson on September 2, 2012 at 1:38 pm
    I switched back and forth several time between 8.2.2 and 9.0b2 without any problem.
    Last week I upgraded to 9.0b3, today I need to fix some credits problem for a closed project several months ago, which you know always happens for oversea distributions. And the upgraded projects crash 9.0b, so I have to switch back to 8.2.2, after start it, I got this popup “Insufficient memory (4095 MB) to allocate 4000 buffers on site 1.”
    Please help me on this.
    Nick Anderson replied 14 years ago 5 Members · 7 Replies
  • 7 Replies
  • Sascha Haber
    September 2, 2012 at 2:17 pm
    We can help you if we would know about your system.
    Also you could export the project and we could test it.
    Just one more thing, R9b3 loves 24 gig of RAM and Lion or Mountain Lion.
    A slice of color…
    DaVinci 9b3 OSX 10.8
    MacPro 5.1 2×2,4 24GB
    RAID0 8TB
    GTX 470 / Quadro 4000
    Extreme 3D+
    Colorist / Aerial footage nerd
    https://vimeo.com/saschahaber
  • Peter Chamberlain
    September 2, 2012 at 2:20 pm
    Could you help us a little, OS? Version, ram on board? Gpu? Etc.
  • Nick Anderson
    September 2, 2012 at 2:41 pm
    Sascha, the project, was running smooth under 8.2.2 months before, under the same hardware/OS environment.
    And maybe my last post was sort of confusing, now Resolve 8.2.2 runs improperly even before load the project.
    BTW, although 24giga ram and Lion were recommended. As I didn’t have time to upgrade my system yet. My v9.0 has done another feature also upgraded from v8.2.2, which got 2000 redone shots and 600 vfx DPX shots, smooth like silk.
  • Nick Anderson
    September 2, 2012 at 2:45 pm
    OS 10.6.8
    12G Ram
    GTX 9600 for GUI
    GTX 480 for CUDA
    8.2.2 was running smooth two weeks ago, which as I said, switched back and forth between v9.0b2 and v8.2.2, for more than 10 times.
    Today was the first time I switch back to v8.2.2 after upgrade to v9.0b3, and everything just failed.
    OS/System were the same, nothing changed.
  • Mikee Carpinter
    September 2, 2012 at 8:59 pm
    I had the same issue and when I changed my kern back to 32 bit mode 8.2 worked again.
    Maybe worth trying? Not sure if 8.2 works on a 64 bit OS
  • Anish Prithviraj
    September 3, 2012 at 3:00 am
    Hi Nick,
    Since 9.0 is 64 bit, it can use a lot more memory. In order to go back to 8.2.2 settings, just open Preferences in Resolve (in 8.2.2), press save and restart the app. This will reset the settings to 8.2.2 defaults.
    When you switch back to 9.0, just repeat the same process to go back to 9.0 settings.
    Anish
  • Nick Anderson
    September 3, 2012 at 4:19 pm
    Thanks Anish! This worked and u really saved my a**!
