Activity › Forums › Apple Final Cut Pro Legacy › insufficient material?
Posted by Patrick Bronte on October 25, 2009 at 3:44 amWhat am I doing/not doing to get ‘insufficient material to make edit’ when trying to apply a transition effect?
I would really appreciate it If anyone could recommend any FCP effects training that helped them …
Steven Gladstone replied 16 years, 10 months ago 3 Members · 5 Replies -
Zane Barker
October 25, 2009 at 5:32 amFor a transition to work there must be a little extra footage at the end of the clip you are transitioning from and also on the clip you are transitioning to.
I’ll bet a million dollars you are trying to add a transition onto a clip that does not have the extra room.
There are no “technical solutions” to your “artistic problems”.
Don’t let technology get in the way of your creativity! -
Patrick Bronte
October 25, 2009 at 5:39 amSo when adding clips to the timeline from the viewer, you must include handles in order to apply transitions etc….?
Cant you just center a transition on the cut…?
thanks for the tip
Zane Barker
October 25, 2009 at 5:42 amhttps://www.kenstone.net/fcp_homepage/basic_transitions.html
Steven Gladstone
November 17, 2009 at 7:11 amI get that same error message sometimes, even though I am doing an insert edit and not an insert with transition. I can be annoying.
Steven Gladstone
https://www.gladstonefilms.com -
Steven Gladstone
November 17, 2009 at 7:12 amI get that same error message sometimes, even though I am doing an insert edit and not an insert with transition. It can be annoying.
Steven Gladstone
