Activity Forums Adobe Premiere Pro Insufficient disc space for burning ?
  • Insufficient disc space for burning ?
    Posted by Joe Landau on August 15, 2007 at 2:20 am
    I get the message “Insufficient disc space for burning” when I try to burn a DVD in PP 2.0.
    The timeline is 70 min. long.
    I am specifying – NTSC DV 16:9 High Quality7MB CBR 1 Pass
    Quality 5.0
    How can I fit the movie on the disc?
    The three HD associated with the project are
    C: – PP program resides here. Available space 445 GB
    H: – My project assets are stored here. Available space 100 GB
    I: – Media, Preview, Scratch disks and the project file. Available space 223 GB
    Shane Lawrence replied 19 years, 1 month ago 5 Members · 4 Replies
  • Harm Millaard
    August 15, 2007 at 6:13 am
    Try with a slightly slower bitrate, like 6.5Mb
  • Jeff Brown
    August 15, 2007 at 1:12 pm
    You want to specify DVD-video, not DV, if you are trying to make a “playback” DVD. That will use MPEG encoding.
    -jeff
  • Steven L. gotz
    August 15, 2007 at 2:07 pm
    Well, 70 minutes does not fit well at 7Mb using CBR.
    Try 2 pass VBR with a bottom end at 5Mb and the target at 6.5 with a max of 7. That ought to get you closer.
    There are bit rate calculators online to help you. Like this one: https://www.videohelp.com/calc.htm
    Steven
    https://www.stevengotz.com
  • Shane Lawrence
    August 15, 2007 at 3:46 pm
    another possibility is to export it into Encore, which should automatically figure out the maximum bit rate when you go to burn it to disc.
