Activity Forums Adobe After Effects Instant HD – resize Beta to HD pixel dimensions
  • Instant HD – resize Beta to HD pixel dimensions
    Posted by Tiya Gordon on August 15, 2006 at 9:47 pm
    Could anyone recomend software/plug in (including thoughts and reviews on Red Giant’s instant HD) that could resize beta 640×480 to 1024×1280?
    Thanks.
    Tiya Gordon replied 20 years ago 4 Members · 5 Replies
  • Matthew Lundstrom
    August 16, 2006 at 1:40 am
    You can download the demo of Instant HD and do your own tests to see if it gives you the quality you want before spending your money.
    Although an even better solution would be to download the 30 day trial of Apple Shake:
    https://www.apple.com/shake/trial/
    Shake has a pretty powerful resizing feature when importing footage, complete with anti-aliasing any jaggies that might result, and it does a good job of boosting detail without boosting any grain your footage might have.
    The trial version features full, non-watermarked, rendering capabilities. You just can’t save, but since what you need to do only requires a couple clicks, and changing a few settings I don’t think you’ll be needing the save feature.
  • Roland R. kahlenberg
    August 16, 2006 at 2:43 am
    I’ve only tested one uprezzing software and that’s Instant HD. It’s not magic but it’s ok for most stuff. Where it fails and I expect where others will also fail is with graphics with alpha channels. On live video, they should be fine. And Instant HD works only with progressive frames. If you have interlaced footage, then you’ll need to convert them to progressive first. The Instant HD manual covers this step. You may also want to look at digital anarchy’s Resizer plugin. And then there’s one from algolith although they never replied to my enquiries on receiving a demo version.
    HTH
    Roland Kahlenberg
    broadcastGEMs
    customizable animated backdrops with Adobe After Effects project files
  • Tiya Gordon
    August 16, 2006 at 2:12 pm
    Thank you.
    I appreciate the feedback and will look into the others but most likely give Instant HD a try.
  • Jason Connolly
    August 17, 2006 at 4:02 pm
    Hey, Tiya-
    I’ve heard good things about Digital Anarchy’s Re-Sizer plug-in:
    https://digitalanarchy.com/resizer/resizer_main.html
    I’ve never used it, but thought I’d mention it as an option.
    Cheers,
    Jason
  • Tiya Gordon
    August 17, 2006 at 4:09 pm
    Thanks Jason. We are playing with Instant HD right now but I will keep this in mind in case we need to try some thing new.
