Activity Forums Adobe After Effects Instant HD Plug in Question
  • Instant HD Plug in Question
    Posted by Pouyan Fard on September 8, 2008 at 7:58 pm
    Hello
    I have some super 8mm footage that I need to use in an HDV (1080p) project. The film is already scanned in SD. Has anyone tried the Instant HD plugin and how good does it look?
    I can scan the film in HD but that costs a lot but before buying the plugin I wanted to know if anyone has tried this??
    Thanks alot in advance
    cheers
    Pouyan Fard
    Clyde Villegas replied 18 years ago 4 Members · 5 Replies
  • Chris Wright
    September 8, 2008 at 8:18 pm
    it will have grain, so remove grain before blow up. instant HD works really well. I think you can download the demo and it leaves a -x- in middle of screen. don’t forget to set your color management up in HD color, and the SD interpret color command will match because it fits inside the HDTV color space.
  • Tim Kolb
    September 8, 2008 at 8:41 pm
    Instant HD is sweet…worth the money after you use it once.
    I’d recommend it.
    TimK,
    Director, Consultant
    Kolb Productions,
    CPO, Digieffects
  • Pouyan Fard
    September 8, 2008 at 8:56 pm
    Hello Chris
    thanks for the respond. For removing the grain from the footage is there a good way that you can recommend?
    thanks again
    Pouyan
  • Chris Wright
    September 8, 2008 at 10:02 pm
    its AE’s noise and grain->remove grain
  • Clyde Villegas
    September 10, 2008 at 10:28 am
    How does Instant HD stretch the picture without degrading it? Is that possible to do with the available effects in AE7? Thanks and God bless.
