Activity Forums Adobe After Effects Expressions Instant color change on layer every few frames.
  • Instant color change on layer every few frames.
    Posted by Joey Harvey on February 6, 2014 at 10:21 am
    I am trying to get a layer to change colour instantly every few frames but stay within set range eg. different shades of green.
    I have had some success by adding the Fill effect to a layer,
    setting a suitable starting color, and then putting a wiggle expression on that color.
    This enables me to control the speed of change and limit the range of colours,
    but the colour changes smoothly and I want to create something that changes colour instantly.
    I have also tried using the random expression but can’t work out how to slow this down so it doesn’t change on every frame.
    Can anyone help?
    Thank you!
    wiggle (3,0.2) // causes colours to change gradually which I don't want
    and also tried
    random ([0,0.5,0,0.5]) // which causes erratic colour changes and I don't understand how to stop it changing on every frame
    Joey Harvey replied 12 years, 6 months ago 2 Members · 4 Replies
  • Dan Ebberts
    February 6, 2014 at 2:34 pm
    Something like this should slow things down:
    framesPerColor = 5;
    seg = Math.floor(timeToFrames(time)/framesPerColor);
    seedRandom(seg,true);
    value + [0,random(.5),0,0]
    Dan
  • Joey Harvey
    February 6, 2014 at 3:27 pm
    Lovely! That is great, thank you!
    In relation to this solution, would you be able to explain how the 4 digit color value is broken down? [0,0,0,0]
    My guess is that its something like [Red,Green,Blue,?] – is that right? If so, what is the value I have written as ‘?’
  • Dan Ebberts
    February 6, 2014 at 3:42 pm
    Alpha. Sometimes it isn’t used (as with the Fill effect), but it needs to be there.
    Dan
  • Joey Harvey
    February 6, 2014 at 4:26 pm
    Of course!
    That makes a lot of sense. Thank you very much for your time!
