Activity Forums Maxon Cinema 4D Instance to Object with Animation
  • Instance to Object with Animation
    Posted by Aron Kantor on April 9, 2010 at 12:26 am
    I’ve modeled a scene using 100s of instances of a light bulb. I animated the light in the bulb, and now I want to convert the instances to objects so I can stagger the keyframes of when the lights are coming on. However, when I make the instances into editable objects, the animation from the first object doesn’t carry over. I also tried copying and pasting the keyframes, but I can’t seem to paste parameter keyframes.
    Is there a simple solution that I am overlooking, or is this not possible?
    THANKS!
    Aron Kantor replied 16 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
