Activity Forums Blackmagic Design Installing the card!!! Urgent please help!!
  • Installing the card!!! Urgent please help!!
    Posted by Tomislav Rukavina on September 27, 2005 at 8:58 am
    Hi!
    Just got a new DL Extreme card. Its in the second slot from the top.
    the problem: Cant get any picture on my external monitor. All I get is a grey screen with 2 vertical green lines. The driver set is 5.1. Tried out all the settings in sys pref. I use the card for now just for video desktop – no input signal.
    Any clues?
    Luke… anybody…?
    G5 2.0 2 G RAM
    10.4.2
    QT 7 Pro
    thnx
    tom
    Olivier Jean replied 20 years, 11 months ago 4 Members · 6 Replies
  • Olivier Jean
    September 27, 2005 at 11:06 am
    HI,
    Is your G5 Dual 2GHz a Pci-x Model ?
    Regards
    Olivier Jean
    Powermedia Systems
    Sydney Australia
  • Tomislav Rukavina
    September 27, 2005 at 1:38 pm
    Yes, the latest model. Just came a week ago. Forgot to say – im monitoring/using for video desktop only analog connectors (component – Y etc.). No other connections on the card are beeing used – no input. Could this be the problem?
    thnx
  • Kaspar Kallas
    September 27, 2005 at 4:40 pm
    The latest model of DP 2GHz is not PCI-X, sorry.
    And apple/blackmagic have some unresolved issues with this mobo
    -Kaspar
  • Tomislav Rukavina
    September 27, 2005 at 4:46 pm
    The BM maula says that its not necessary for the card to be in a PCI X slot. I also have a ATTO SCSII controler. Any recomendations on the slots these two cards sould be installed (DL Extreme & ATTO ULD4)?
    thnx
  • Justin Coleman
    September 27, 2005 at 10:35 pm
    Tom,
    Im afraid you have fallen into a little trap here, you are correct that you do not need a PCI-X slot for this card, but you do need a qualifying mac g5, and im afriad you dont have one. Unless I’m wrong, as of this summer or spring when an apple firmware update was released, none of the G5’s without PCI-X slots will support BM cards of any kind. I personally bought a Dual G5 1.8 this year and after purchasing found this out to great frustration. I returned the machine and went back to my old G4 which will support the Deck Link HD card used for SD only.
    This isnt easy to hear but it is the truth! Read some of the fine print on the BM website and you will see.
    Justin
  • Olivier Jean
    September 29, 2005 at 12:10 pm
    HI,
    BTW this has been discussed on this forum quite a lot
    and is well documented on the Blackmagic website.
    Please research before you buy or ask your video reseller, it will save
    you a lot of assles in the long run ;-).
    Regards
    Olivier Jean
    Powermedia Systems
    Sydney Australia
