Activity › Forums › Apple Final Cut Pro Legacy › Installing new Ram
  • Installing new Ram
    Posted by Guy Voisin on July 13, 2008 at 6:39 pm
    HI
    Well I have tried and searched the forums for an answer but I guess I just didn’t go far enough, lack of patience today, so I apologize if this has been asked already, it most likely has.
    I have a MacPro 2x 2.8quad core, and I have recently installed ram. I was told that it was better to install the same manufacturer type ram on the same riser, therefore I installed 2x 2GB(third Party) on riserA and 2x 1GB on riserB originals from Apple.
    Is this the best set-up or should I be installing 3GB on each riser?
    GUY
    GuyNeb
    Guy Voisin replied 18 years, 2 months ago 3 Members · 4 Replies
  • Todd Reid
    July 13, 2008 at 10:15 pm
    It is my understanding that you should mirror each riser, so yes, I suggest 3GB on each.
    Also, I would put your 2GB in slot A of each riser, then the 1GB in slot B.
    Some may say to use the Apple RAM first, but I would use the larger RAM first.
    Not sure technically why that makes a difference, but that’s what I’ve always heard and done.
    Maybe someone can explain why.
  • Guy Voisin
    July 14, 2008 at 2:14 am
    Hi again,
    Well after some digging I found what I needed,thanks for your response. Here is the link I found in the MacPro user manual for upgrading Ram.
    https://manuals.info.apple.com/en_US/MacPro_MemoryDIMM_DIY.pdf
    Thanks again
    GuyNeb
  • Jeff Carpenter
    July 14, 2008 at 2:22 am
    Do you have the Mac Pro’s user manual? Page 33 and 34 have little pictures explaining this. I always that out when doing RAM. I’ve done it many times, but I still use that little drawing, every time. I find it makes it much easier.
  • Guy Voisin
    July 14, 2008 at 2:29 am
    Yeh, I have a users manual but I was just unsure of the way they should be put in, the order if size was important or manufacturer and finally i found the answer.
    Thanks for the reply.
    GuyNeb
