Activity Forums Apple OS X installing Mac OSx on G4 laptop with broken CD drive
  • installing Mac OSx on G4 laptop with broken CD drive
    Posted by Sam Pope on June 15, 2010 at 6:45 pm
    installing Mac OSx on G4 laptop with broken CD drive. I am using a mac book pro as the main computer and my G4 as a drive now. Online I have seen various ways to do this that all require formatting your disk and using a 3rd party software to be able to install the installation disk on the hard drive. Any clear ideas on how to do this
    Alexander Kallas replied 16 years, 2 months ago 3 Members · 3 Replies
  • Zane Barker
    June 16, 2010 at 4:24 am
    Put your G4 install disk into the optical drive of the MacBook Pro and then restart it holding down the T key thus putting the machine into target mode. You can them boot the G4 off the install disk by connecting the 2 computers via FireWire.
    Hindsight is always 1080p
  • Sam Pope
    June 16, 2010 at 3:41 pm
    thanks but that did not work at all, computer that is not hard drive setup just says to keep restarting but never installs. I tried to clone Mac os x onto a hardrive following these directions
    https://lowendmac.com/ed/royal/08sr/clone-mac-os-x.html
    but also did not work.
    Here is my current situation
    I have a Mac Powerbook G4 (2004 i think). The hard drive crashed, and i got a guy to replace it with a 320g drive (i understand it may not be able to use it all). He was unable to intstall mac os x on the computer, partially because my cd drive also does not work. i followed your instructions on
    and used a macbook pro to load super duper and then format and install on my g4 using it as a drive(pressing T as it starts up) After doing this my computer still will not boot up just the folder with the ?.
    Any suggestions?
    Is buying and external cd romm drive my best option?
    I have an original Tiger 10.4 disk. I was actually running SnowLepord on my g4 for the last year or so with no problem but Tiger is the only disk i currently can find.
    Please help, this is one of my work computers. I’ll send out some of our films to you.
    Thanks, Chris
  • Alexander Kallas
    June 23, 2010 at 12:05 pm
    Create a disc image of the install disc on the donor Mac, and make your G4 the fire-wire target.
    Transfer the disc image to the G4 and open it there.
    Cheers
    Alexander
