Activity Forums Square Box CatDV Installing and using CatDV on a PowerPC Mac
  • Installing and using CatDV on a PowerPC Mac
    Posted by Khashyar Darvich on October 8, 2012 at 4:38 pm
    Hi Everyone,
    I have a PowerPC G5 Quad Mac with OS 10.5 installed, and wondered whether CatDV v.10 would install and work.
    Does anyone regularly use CatDV on their PowerPC Mac without issues?
    Thank you for your thoughts and feedback about this.
    I did read on the squarebox website that although CatDV v9 is not officially supported for PowerPC Macs, that they do offer a way for them to work:
    Question:
    Can I use CatDV 9 on a PowerPC Macintosh?
    Answer:
    Officially the answer is no, CatDV 9 requires an Intel Macintosh, because of changes Apple made in removing PPC support from all their development tools. However, there is a workaround which means you may be able to run CatDV 9 on some PowerPC machines running Mac OS X 10.5 by manually copying over some files from an old application bundle.
    To do this, download both the latest version of CatDV or CatDV Pro, and also the older version CatDV Pro 9.0.2. In each case, right click on the application bundle in the Finder and choose Show Package Contents. Copy the following files from 9.0.2 to replace the same files in the current version:
    Contents/MacOS/CatDV
    Contents/Resources/Java/libCatDV.jnilib
    Contents/Resources/Java/libMacUtil.jnilib
    Contents/Resources/Java/libQTLibjnilib
    The modified latest version should then run on PowerPC Macs, but please be aware that this workaround is not officially supported or guaranteed to continue to work with all future updates.
    Producer-Director
    Wakan Films
    Hollywood, CA
    http://www.wakan.com
    Rolf Howarth replied 13 years, 10 months ago 3 Members · 5 Replies
  • Bryson Jones
    October 9, 2012 at 3:15 am
    I have clients who do this for loggers so they can use their old macs ’til they die. (The macs, not the loggers.)
    It works, but please don’t judge the program based on this config. Performance may be compromised.
    bryson
    bryson “at” northshoreautomation.com
  • Khashyar Darvich
    October 9, 2012 at 5:45 am
    Thank you, Bryson.
    Yes, hopefully neither dies for a long while 🙂
    That’s exactly the case with my G5 Quad… I thought it would be perfect to use for logging, since I have a MacBook Pro for editing.
    Do you think that with this configuration, that performance will be so slow as to not be practical?
    Or, do you think that the specs of a Mac G5 Quad is fast enough for normal logging with CatDV?
    Also, do you happen to know the answer to my other Catdv question in this forum regarding whether you can install Catdv on a laptop and desktop owned by the same licensee?
    Thank you again.
    Khashyar
    Producer-Director
    Wakan Films
    Hollywood, CA
  • Bryson Jones
    October 9, 2012 at 6:11 pm
    Sorry to lag, clients first, of course.
    It’s fine for playing proxy files in my experience.
    Obviously PowerPC won’t play certain compressed formats well, and indeed some codecs don’t exist for non-Intel machines so that’s what that was based on.
    In the end, and the good thing about CatDV, you can just try it and see. But proxy can easily be played on most Macs from this century.
    bryson
  • Khashyar Darvich
    October 9, 2012 at 6:23 pm
    Thank you very much, Bryson.
    Yes, of course work and clients come first 🙂
    Also, I wanted to compliment you on the great job you did on the Youtube CatDV talk that you gave.
    Khashyar
    Producer-Director
    Wakan Films
    Hollywood, CA
  • Rolf Howarth
    October 20, 2012 at 9:46 pm
    Just to re-iterate what Bryson says – if you’re at all unsure about whether CatDV will work on a particular configuration or with particular files, just drop us a line to request an evaluation license. This will be a fully functional but time-limited version of the full application, so you can always test out your workflow on your hardware and with your media files before committing to making a purchase.
