Activity › Forums › Apple OS X › Installing a third internal ATA Hard drive on a g4
  • Rich Rubasch
    January 29, 2006 at 10:32 pm
    If you don’t plan on moving the computer around it would be fine. Not a bad idea either. The ATA bus that has the usual Zip and DVD drive is a second bus. Take out the zip drive and you could install a second ATA drive without a card. I don’t use zips much anymore and I do have a G4 with a zip drive so this would be an option for me as well.
    Basically any hard drive needs airflow around it…if you can find a way to mount it in the zip carriage that would be fine.
    If I was to buy a PCI card, I would suggest getting two ATA drives and stripe them into a RAID…much better performance and twice the storage.
    Rich Rubasch
    Tilt Media
