Activity Forums Apple OS X installing a different OS on a partition
  • installing a different OS on a partition
    Posted by Christian Hayden on January 14, 2008 at 2:38 am
    hello, i have 2 MacBook Pros and would like to run both Tiger and Leopard on them. Can I install Tiger on one partition and the Leopard on a different partition? If so, exactly how do you go about that…step by step would be helpful:)
    thank you.
    Zane Barker replied 18 years, 8 months ago 2 Members · 1 Reply
  • Zane Barker
    January 14, 2008 at 6:07 pm
    You would need to use disk utility to partition the drive. In disk utility select the drive and then select partition and set your partition sizes.
    Just remember you cant partition a drive that you are booted from, and that partitioning the drive will erase EVERYTHING that is on the drive.
    Don’t let technology get in the way of your creativity!
