Activity Forums Boris FX Installation Problem with Boris in Premiere Pro
  • Installation Problem with Boris in Premiere Pro
    Posted by Lester23 on July 11, 2006 at 12:58 pm
    I have Boris Fx and Red, whe I try to installed I click on the premiere pro box the I continue installing the rpogram and it tell me it can’t find Premiere Pro so I have to find it myslef so I installe it in C/PROGRAM FILES/ADOBE PREMIERE PRO 2.0/PLUGINS so when it finish installing it I open pro and nothing appeard. I decide the to installed doing the same in C/PROGRAM FILES/ADOBE PREMIERE PRO 2.0/PLUGINS/EN US, now when I open Premiere Pro it appeard but when I open Fx to use it gives me a error I will appreciatte your help to learn where to installed. I will appreciatte ytour help.
    Paul Fx replied 20 years, 2 months ago 2 Members · 1 Reply
  • Paul Fx
    July 19, 2006 at 6:11 pm
    My suggestion is to uninstall RED and FX. First use the remove option from the CD and then search for any other files or folders on your machine from Boris, RED and FX and delete those as well. Restart the machine and then reinstall RED into the Premiere plugins folder located here: C:\Program Files\Adobe\Premiere Pro 2.0\Plug-ins\en_US
    If this doesn’t work, please go to the link below and fill out a support contact form and if you could, please provide a little more info about your system. thanks,
    Paul
    https://www.borisfx.com/support/problem_form.php
