Installation Problem
I use OSX 10.3.9 on an IMac G4 and just bought Avid Xpress DV 4.6. Somehow I don’t get it installed.
I install the programme from the cd. In the window “AvidXpress DV Installer” I choose for “full install”. In the same window is written that the disc space needed is 173.268 k and the space availbae is 4GB (so that should be OK I assume). In the same window is written: the folder “ALLEditors” will be created in the folder “applications” on the disc Macintosh HD and for install location I choose for “Macintosh HD”. Then I press the button “Install”. The installations seems to start, the installation bar starts moving until somewhere half way and the suddenly stops, the installation window with the installation bar disappears and the old window “AvidXpress DV Installer” appears again, so I’m back to zero. I don’t understand what’s happening. What do I do wrong?Please help!
