Activity Forums DaVinci Resolve Install v.15 without deleting or messing up v.14.3?
  • Install v.15 without deleting or messing up v.14.3?
    Posted by Duke Sweden on April 9, 2018 at 7:09 pm
    I checked the directories and it doesn’t differentiate between versions. Will the new version 15 of Resolve overwrite 14.3?
    Dell XPS 8920
    Intel i7 core 7700 build
    GeForce GTX 1050ti
    32 Gigs of RAM
    3 7200 RPM SATA Drives
    Windows 10 64-bit
    DaVinci Resolve 14.3
    Duke Sweden replied 8 years, 5 months ago 4 Members · 12 Replies
  • 12 Replies
  • Tero Ahlfors
    April 9, 2018 at 8:20 pm
    [Duke Sweden] “Will the new version 15 of Resolve overwrite 14.3?”
    New versions will overwrite the old ones and also update the database. And this is a beta so if you upgrade you’ll probably want to backup your database and/or your projects.
  • Duke Sweden
    April 9, 2018 at 8:28 pm
    Of course! I wouldn’t want to deprive the world of my original out of camera copy of “I Am A GH5 179d AF Fix Addict”! ????
    So then my next question is, if you were to install the beta of v.15 how would you do so? And do you plan to?
    Dell XPS 8920
    GeForce GTX 1050ti
    32 Gigs of RAM
    Windows 10 64-bit
  • Tero Ahlfors
    April 9, 2018 at 8:47 pm
    [Duke Sweden] “So then my next question is, if you were to install the beta of v.15 how would you do so?”
    Doubleclick the installer and follow the directions. Probably. You do what you do, dude. ????
    [Duke Sweden] “And do you plan to?”
    Already did on my home computer. Probably won’t do that on my work computer until it’s out of beta. I managed to find a repeatable crash with a certain tool in the new Fusion page.
  • Duke Sweden
    April 9, 2018 at 9:09 pm
    Hey! If I wanted sarcasm I’d have lunch with my mother! ????
    So I guess I’ll wait until it’s out of beta as well. I got a good thing going here, no sense in messing it up for a feature I’ll probably never use (Fusion).
    Dell XPS 8920
    GeForce GTX 1050ti
    32 Gigs of RAM
    Windows 10 64-bit
  • Tero Ahlfors
    April 10, 2018 at 6:23 am
    [Duke Sweden] “I got a good thing going here, no sense in messing it up for a feature I’ll probably never use (Fusion).”
    I would actually recommend learning a bit of Fusion. It’ll make projects where you need keying etc. a bit simpler because you have actual comp tools to do it instead of using the color page secondaries for that.
  • Duke Sweden
    April 10, 2018 at 11:09 am
    But I like using color page secondaries to key. It’s really easy and I get great keys. Also it’s been months since I’ve come up with any new ideas for green screen comedies. I downloaded the trial version of Fusion and it looked nowhere near as intuitive as After Effects. Who knows, I may get the bug by the time 15 is out of beta.
    Cheers!
    Dell XPS 8920
    GeForce GTX 1050ti
    32 Gigs of RAM
    Windows 10 64-bit
  • Duke Sweden
    April 10, 2018 at 5:38 pm
    Well, I took the plunge, and the results are so-so. As you said there’s a crashing problem with Fusion. I do like that you can open multiple timelines in tabs, among other tweaks to the interface (I also like that you can open a LUTs panel and scroll over a LUT to see the effect on your clip.
    The one thing that pisses me off is, the official v.15 youtube video shows an audio effect called Noise Reduction. It’s listed in the user manual, but it doesn’t show up in the list of effects. Grrrrr….
    Anyway, I would recommend that you guys who do this for a living stay away. It still has some tweaking that needs to be done.
    Dell XPS 8920
    GeForce GTX 1050ti
    32 Gigs of RAM
    Windows 10 64-bit
  • Duke Sweden
    April 10, 2018 at 10:40 pm
    EDIT: Hey, Tero. Just saw a fix for the Fusion crashes if you’re interested. Just go into Preferences and check “Always Use CPU for Fusion” or words to that effect.
    Dell XPS 8920
    GeForce GTX 1050ti
    32 Gigs of RAM
    Windows 10 64-bit
  • Glenn Sakatch
    April 12, 2018 at 1:31 am
    You can usually install two different versions on a mac, but you will have to have separate databases.
    Windows I don’t think there is any way to do it, without a dual boot. (or virtual hard drive)
    Glenn
  • Duke Sweden
    April 12, 2018 at 2:46 am
    Hey Glenn. I have v.14.3 installer just in case but so far v. 15 looks pretty cool and, as I told Tero, there is a temporary fix to keep Fusion from crashing. I didn’t want to run both versions, I just wanted to make sure I could go back to 14.3 if necessary.
    Cheers!
    Dell XPS 8920
    GeForce GTX 1050ti
    32 Gigs of RAM
    Windows 10 64-bit
