Activity › Forums › RE:Vision Effects › Install Twixtor in Smoke 2012 MAC OS
Posted by Pedro Santos on August 26, 2011 at 8:14 pmHello, i am having problems in install twixtor in smoke mac 2012, i do the instalation and when i use the plugin in the bottom sparks, appear the message – Cannot load: usr/Discreet/sparks/Twixtor/spark. But i am with the plugin in this folder. I instaled it correctly.
Peter Litwinowicz replied 14 years, 10 months ago 3 Members · 7 Replies -
Pierre Jasmin
August 26, 2011 at 8:21 pmAre you at the same site as Ricardo that wrote to techsupport here?
Pierre
RE:Vision Effects -
Peter Litwinowicz
August 26, 2011 at 8:23 pmI presume you are working with Ricardo Gomes that I’ve been communicating with by email?
can you run the following two commands in Terminal and return to me what is printed out?
ls -ld /usr/discreet/sparks
ls -ld /usr/discreet/sparks/*Pete
RE:Vision Effects, Inc. -
Pedro Santos
August 29, 2011 at 3:29 pmHI there,
thanks for your help,
I’ve run the commands and got the following lines:
conspiracao-Filmess-Mac-Pro-2:~ smoke_mac$ ls -ld /usr/discreet/sparks/
drwxrwxrwx 5 root wheel 170 Aug 26 17:05 /usr/discreet/sparks/conspiracao-Filmess-Mac-Pro-2:~ smoke_mac$ ls -ld /usr/discreet/sparks/*
-rwxrwxrwx@ 1 smoke_mac staff 7863576 Apr 4 13:26 /usr/discreet/sparks/DesktopTwixtor.spark
-rwxr-xr-x@ 1 smoke_mac staff 7863752 Apr 4 13:26 /usr/discreet/sparks/Twixtor.spark
drwxrwxrwx 3 root wheel 102 Apr 2 19:26 /usr/discreet/sparks/links -
Peter Litwinowicz
August 29, 2011 at 6:01 pmcan you please set the permissions on Twixtor.spark to be read/writeable by everyone?
that is, as root (or as an administrator), run
chmod ugo+rwx /usr/discreet/sparks/Twixtor.sparkAlso, can you run
? (I presume that won’t tell me much)Also, if that doesn’t work, can you send me what is displayed in the system console when trying to load the Twixtor spark?
pete -
Pierre Jasmin
August 29, 2011 at 6:06 pmOr send the log file in /usr/discreet/log
You need to start flame from a shell to get message in console I think. (That is open a shell and type flame)Pierre
Peter Litwinowicz
August 29, 2011 at 6:26 pmPlease disregard Pierre’s comment about starting “flame’. (yes I know you are running smoke!)
Perhaps the log file you will need to send is
/usr/discreet/log/ifffs.logAnd send us any other log files written to the disk today that are in /usr/discreet/log
Also, open the Apple program Console, and send us any other error messages written to the console.
We should take this offline, please write to us at tecsupport (at) revisionfx (dot) com.
pete
