Activity Forums VEGAS Pro Install issue on Win 10 with DVD Architect 6
  • Install issue on Win 10 with DVD Architect 6
    Posted by Dennis Cupp on January 15, 2017 at 6:28 pm
    Keep trying to install DVD Architect 6 on a new OS Drive.
    When the “Downloading Microsoft . net framework 3.5 SP1” screen is up it gets to about 90% then i get a “Download was Corrupted” error message and it aborts the install.
    Tried it several times with the same results.
    HELP!
    Francois Pénzes replied 9 years, 7 months ago 2 Members · 6 Replies
  • Francois Pénzes
    January 16, 2017 at 1:47 am
    Hi Dennis
    Have tried other sources for your download ?
    Cheers !
    PC Win 7 64-bit 16gb Intel® Core™i7-2600k Quad Core 3.40GHz NVIDIA GEFORCE GTX 550 Ti
    Cameras: Canon XF305 + Canon XH-A1
    \’\’When the cutting stops, the editing begins…\’\’
  • Dennis Cupp
    January 16, 2017 at 2:31 pm
    What other sources are there?
    Also, when running the DVD Arch exe program, it is the one looking for that file. If i have it downloaded and installed will it recognize it and move past that part of the install?
  • Francois Pénzes
    January 17, 2017 at 12:21 am
    Hi Dennis
    Try these links, they may be of some help. Net Framework can be a challenging task on Win 10 sometimes.
    https://www.youtube.com/watch?v=xo-l-iwdD5Q
    https://www.youtube.com/watch?v=rX1ajemGaZY
    Let me know how it goes.
    Cheers !
  • Francois Pénzes
    January 17, 2017 at 12:24 am
    Forgot to add that if you type: Microsoft.net framework 3.5 SP1 in Google, it will give you other site options.
  • Dennis Cupp
    January 17, 2017 at 1:39 pm
    Thanks for the video.
    So let me ask you this. If i successfully install it with this method and go to install DVD Archt, will the installer see it already installed and skip that step?
  • Francois Pénzes
    January 18, 2017 at 12:13 am
    Hi Dennis
    Mine did. It should but, bare in mind that not all PCs are built the same nor are the OS’s installed the same way. Your configuration may need some tweaking.
    Happy trails !
